set recording length
isacchino
Post by isacchino » Mon Apr 27, 2009 12:49 am
Hello,
When I make a recording, I am often not in front of Audacity to stop the recording at the correct time and end up with a huge file that is mostly silence. I am wondering if there is a way to tell Audacity how long the recording is supposed to be? That way, even if I am not in front of Audacity to stop the recording at the appropriate time, it will stop itself.
Thanks, Isaac
Re: set recording length
Post by kozikowski » Mon Apr 27, 2009 12:52 am
Not in 1.2. I think there's a timer in 1.3.
waxcylinder
Post by waxcylinder » Mon Apr 27, 2009 10:09 am
Yes indeed, there is a timer in 1.3.x - don't be too wary of using the beta 1.3 version 1.3.7 is fairly mature now and pretty stable - I use it all the time.
isacchino
Post by isacchino » Mon May 04, 2009 10:27 pm
Great!
FYI the timer is located at Transport > Timer Record in Audacity 1.3.7.
waxcylinder
Post by waxcylinder » Tue May 05, 2009 8:12 am
Or you can invoke it with the keyboard shortcut SHIFT+T
