Hello,
I would like to use USB input to Audacity to bypass my laptops sound card, but I haven't been able to get Audacity to recognize the USB input. I am using a Behringer UCA202. I have a tape player with line-out RCA plugs running to the UCA202 and then the UCA202 USB plugs into the laptap.
Any suggestions?
Thanks, Isaac
can't get usb input to work
waxcylinder
Re: can't get usb input to work
Windows (and therefore Audacity) should just recognize the USB device when you just plug it in.
You are using a direct USB input and not a USB hub, right?
TRy unplugging the USB plug and re-plugging, or just wiggle it gently. Try a different USB port on your PC. Try plugging and then re-booting. Try replugging after re-booting.
Stevethefiddle who is a very frequent poster to these pages uses a UCA202 (albeit under Linux) so he may have som more informed insights into this particular device and its quirks.
My USB device was eventually recognized by Audacity, though I'm not sure exactly what triggered the recognition. I think it was something simple like you suggested, such as plugging and then re-booting. If I figure it out, I'll post to the forum.
Thanks.
Thanks.
