PLEASE PLEASE PLEASE HELP
Everytime I try to import a song into audacity, it compresses the song into less than one second. I don't know why or how. If anyone could please tell me how to import my songs without this happening or at least how to fix it, that would be great. I appreciate any help I get.
waxcylinder
Re: PLEASE PLEASE PLEASE HELP
You are almost certainly trying to import a file type that Audacity does not support . Audacity Supports WAV, MP3, OGG and FLAC & MP2 in 1.3.
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
WCstevethefiddle wrote:There's a free program called SUPER by erightsoft that can convert most media file types. If you can convert the files to WAV files that should fix the problem.
Thank you! I'll try that.
