Have been using Audacity for years with no problem then all of a sudden this message appeared.
Error while opening sound device.Please check the input device setting & the project sample rate.
Please could someone explain what I have to do.
Cheers
Oldsoul
Sudden fault
Re: Sudden fault
I might be having the same problem
can you confirm?
http://audacityteam.org/forum/viewtopic.php?f=12&t=9637
can you confirm?
