Transferring file to audacity only showingin Mono
funktifeyeno
Post by funktifeyeno » Fri Apr 17, 2009 7:42 am
Hi
I'm having a recurring problem with Audacity.
When I transfer a track to Audacity (I use it for editing purposes) the track will only show in Mono, even though it is a Stereo track.
I can play the track through other sources and it will always play in stereo, but will only show in mono in audacity.
Any ideas
Thanks
D
Re: Transferring file to audacity only showingin Mono
Post by steve » Fri Apr 17, 2009 7:47 am
funktifeyeno wrote:When I transfer a track to Audacity
How are you doing that?
funktifeyeno
Post by funktifeyeno » Fri Apr 17, 2009 8:02 am
Just taking a file from my desktop, dragging and dropping into audacity
Post by steve » Fri Apr 17, 2009 8:24 am
And how do you know that it is a stereo file?
funktifeyeno
Post by funktifeyeno » Fri Apr 24, 2009 8:47 am
yeh, it's a stereo file
I've taken it from my itunes (checked info that's it' stereo), dragged + dropped onto my desktop, then dragged + dropped into audacity
Turns into mono track
Post by steve » Fri Apr 24, 2009 3:33 pm
If you right click on the file on your desktop, then select "properties" you should be able to see what the file type is, the number of audio channels, bit rate/sample rate, and various other information.
scalywg
Post by scalywg » Wed May 20, 2009 10:53 pm
Appologies if this is too obvious - but I found this post when trying solve the same problem. After some reading I worked out that the Audio I/o tab in preferences was hidden - so go to Edit ->Preferences and enlarge that box (pull on the lower right corner)until you can see all the tabs at the top and the go to the AudioI/O and choose 2 channels from the drop down.
