Waveform below 0.0
ad1940
Waveform below 0.0
Post by ad1940 » Thu Apr 16, 2009 4:06 am
This is a probably a simple thing, but I can't find any posts on the topic. Recently switched computers. My mic now generates a waveform at about -0.1 rather than right at 0.0. Anyone know how to fix... greatly appreciate any help.
AD
Re: Waveform below 0.0
Post by steve » Thu Apr 16, 2009 4:28 am
It is probably a hardware fault with the sound card (not uncommon with on-board sound cards).
If you apply the "Normalize" effect with just the "DC off-set" correction selected, then your recordings may be usable, although it does not really "fix" the problem and the sound quality will probably still not be very good.
ad1940
Post by ad1940 » Thu Apr 16, 2009 4:37 am
stevethefiddle wrote:It is probably a hardware fault with the sound card (not uncommon with on-board sound cards).
bummer... thx.
AD
