I apologize if this topic has already been covered, but I have searched the boards and can't seem to find an exact match-
I have an HP desktop with "Sound Effect Manager" - not "RealTek HD Sound Effect Manager", as such I don't have the multi-streaming option available. I have set the Sound Effect Manager to Digital Audio @ 48 khz, and Audacity to the same, however regardless of whether I select "Microsoft Sound Mapper" or "RealTek HD Digital Input" I get the error message to select the correct input/rate. Does anyone know if there is a way to configure Sound Effect Manager so as to make it compatible with Audacity? I have used Audacity on a number of computers and been able to configure it correctly with few issues, but this PC has thwarted me every time I've tried to change an option/feature.
Thanks-
ag
RealTek Audio issue - NOT "HD" Sound
Re: RealTek Audio issue - NOT "HD" Sound
A good first stab at this would be 44100, 16-bit, Stereo. That's the Music CD audio standard and just about everybody supports it.
Does the sound card work with any sound application? Does it capture with Windows Sound Recorder?
Start -> Programs -> Accessories -> Entertainment
Capture a clip and Right-Click > Properties > Advanced and make Windows tell you what it is.
