ION turntable - not receiving sounds
I am using VISTA. It seems as if the software (version 1.2.6) is working and that I am recording the music from the LP but since I cannot hear the music - I am not sure.
waxcylinder
Re: ION turntable - not receiving sounds
USB devices have a habit of hijacking the entire sound – output as well as input – and they don’t tend to have loudspeakers (hence “no sound”).
What you need to do is to direct the Windows sound output to your PC's soundcard Control Panel>Sounds and Audio Devices>Audio>Sound Playback - and make this setting to the PC soundcard.
You may also need to ensure that Audacity sends it output to the PC soundcard Edit>Preferences>Audio>Playback - and set this also to your PC soundcard. You may need to stop and restart Audacity for this setting to take effect.
See: http://audacityteam.org/wiki/index.php? ... _turntable
Thank you. I will try this and let you know if I can do it.
