As i was working on a Greek project I clanged keyboards and typed the name in in Greek. The project would kill Audacity if i tried to export...
after much experimentation i found that i could save the project to a simple English name and I was then able to export....
using GREEK as projct name causes Audacity problems with exp
Re: using GREEK as projct name causes Audacity problems with
Certain characters are magic in computers.
We warn people to only use upper case and lower case letters, numbers, and the dash and underline. That's it. If Windows thinks one of your file name characters is anything else, then it will become unstable. For example, "MyMusic" is not a filename. It's a Windows directory structure. Windows needs to be started and working in the same language you are. I'm betting you can't swap back and forth.
