Pavilion computer. Do you have any idea what the problem might be? HELP!
No Audio on playback
I am having difficulty with playback audio. The first recording I did from the Crosley CR-249 USB turntable was just fine I was able to edit it and export to a WAV file with no problem. The sencond one I tried recorded just fine, but when I went to edit it I could not get any audio, I checked all of my settings, and all of the cables, I tried unpluging the USB connection, that didn't work either, so I checked the connections again. The next time I tried playback I got audio and was able to edit and export my file. Now I can not get audio again, I have checked everyting again still no audio. It seems there is no rhryme or reason to the lack of audio on playback. I am using Windows Vista 64 bit version on a HP
Ginger
Re: No Audio on playback
stevethefiddle,
Your link was helpful but did not actually solve the problem. But to do what it suggested I had to change to Admin. account where I discovered I had audio on playback after I updated my Windows, but when I went back to the standard user account, no audio again. So I re-installed the program under the user account, now I have audio on playback. Hey I don't know how it works it just does. Thank You for your help
