Audacity questions
Re: Audacity questions
Post by steve » Thu May 28, 2009 6:19 pm
Re. the clicking/hiccups - When you load the YouTube page, make sure that the YouTube player is paused while the file downloads (you should see a pink progress bar at the bottom of the video frame). Wait until the file has fully loaded, then click on play.
Exalted Erick wrote:The only noticeable difference between the MP3 and WAV version is that the WAV version is much larger.
It may not be evident on computer speakers, but if you listen through good quality headphones the loss in quality due to MP3 compression is quite noticeable.
For sites that allow WAV format uploads, then compress them before making them accessible, (I think YouTube is in this category), make sure that the peal level of your file is just a little below 0dB (You can use the "Normalize" effect and set it to Normalize to -0.3dB) Then upload it in WAV format. Unfortunately uploading will be rather slow, but that should help to make the best sound quality as the file is only being compressed once, not twice.
You can also try using a "low pass filter" set to about 7kHz on your file before uploading it - this can help the sound quality with some MP3 encoders.
For sites that only allow MP3 uploads, select a high bit rate CBR format. The highest quality MP3 format is 300kbps CBR.
If the site does not recompress the file, but just serves it up in the original MP3 format that you upload it, try using 192kbps CBR (Constant Bit Rate).
Exalted Erick
Post by Exalted Erick » Thu May 28, 2009 8:45 pm
I don't use headphones, so I didn't even think of them.
Listening to the YouTube video in segments or waiting for it to completely load before playing makes no difference. The hiccups are still there.
YouTube and MySpace auto convert audio files from their original bitrate to either 64 or 96 kbps.
I've tested bitrates 64-320. It makes no difference.
Listen to the WAV version on YouTube and tell me if it sounds better than the MP3 version:
youtube.com/erickcolletti.
If it does sound better, then the double conversion is hurting the sound quality, and the best I can do is stick to WAV format.
Post by steve » Fri May 29, 2009 11:23 am
Exalted Erick wrote:Listen to the WAV version on YouTube and tell me if it sounds better than the MP3 version
Tricky to say without a side by side comparison, but it sounds about on par with other YouTube vids.
Done a bit of a Google about the stuttering sound or whatever we are going to call it. Seems like a number of possibilities but none that we can do much about. The quality of the internet connection to YouTube is the main one, but waiting for the download to complete should fix that. The next thing is that the YouTube player is not very efficient and low spec machines, or computers without much free ram are likely to get this issue. I don't know if that applies to you or not?
You know that it is possible to download vids from YouTube and play them in a standalone media player? There are websites such as http://www.farkie.com can do the format conversion - if that site does not work for you, try Googling for another
ezrab
Post by ezrab » Fri May 29, 2009 2:41 pm
Exalted Erick wrote:Koz, you can listen to my music at: youtube.com/erickcolletti. Use 50% speaker volume, or you'll hear a lot of static. :oops: I can't get rid of the static. I've given up. Nobody has a solution.
You must disconnect any webcams from the computer while recording.
Exalted Erick
Post by Exalted Erick » Fri May 29, 2009 7:56 pm
Steve, what's your email address? I'll send you both the WAV and MP3 version for comparison.
I have a mid-level computer with about 780 MBs of free RAM, so that's not it.
I've heard the hiccups (that's what we'll call them) in other YouTubers' videos, so it's not just me.
I don't own a webcam.
Post by steve » Sat May 30, 2009 10:25 am
Exalted Erick wrote:Steve, what's your email address? I'll send you both the WAV and MP3 version for comparison
It would be more convenient for me if you uploaded them to either http://www.sendspace.com/ or http://www.yousendit.com/ (both services can be used free of charge) then post links here.
Exalted Erick wrote:I have a mid-level computer with about 780 MBs of free RAM, so that's not it.
That should be easily capable of playing YouTube smoothly, but it may be worth looking at some optimisations - let's have a look at those files first, then we can move on to optimisations.
Exalted Erick
Post by Exalted Erick » Wed Jun 03, 2009 10:47 pm
Steve, files are up. You still on the case?
