cant record any internal sound from computer
anatomy1
Post by anatomy1 » Sun Mar 01, 2009 11:32 pm
Hey peoples, ive just bought a motu ultralite audio interface which works perfectly, the only flaw is that i cant record anything which isnt hooked up to the interface meaning I cant record any sound thats being played from the internet etc.
Any ideas???
thanks!
Re: cant record any internal sound from computer
Post by kozikowski » Mon Mar 02, 2009 4:10 am
I have two licenses to do this, WireTap for the Mac and Total Recorder for the PC. Sometimes you can force Windows machines to do this by juggling the sound panel settings, but with some of the newer Windows machines you're otta luck.
Windows Control Panel
If this doesn't work, it may never work on your machine without software.
Post by kozikowski » Mon Mar 02, 2009 4:13 am
Some people force this to work by connecting the headphone output back into the Line-In with a short jumper cable. That's not optimal, but sometimes it's good enough.
Post by steve » Mon Mar 02, 2009 8:47 pm
USB and Firewire devices do not have the ability to "record sounds playing on your computer". To get round this limitation, use a pair of audio leads to connect a pair of "Line level outputs" of the motu to a pair of "Line level inputs" (a loop-back connector). This should work very well.
anatomy1
Post by anatomy1 » Wed Mar 04, 2009 1:02 am
i tried to connect 2 jacks from the input to the output but with no prevail. Am i doing something wrong or is there an alternative?
thanks again!
Post by steve » Wed Mar 04, 2009 9:14 pm
First make sure that the sound that you want to record is actually playing through the output sockets.
Then check that you are able to record through the input sockets.
Assuming both of these tests are positive, the bar faulty leads there should be no problem.
anatomy1
Post by anatomy1 » Sun Mar 08, 2009 12:27 am
ive tried adjusting the gain and trim on the motu but im still not getting audacity to record the input. Im pretty sure the leads are in working order as well, tried to look under the audacity preferences but still no solution. I dont know what else to do? any suggestions?
thanks again!
Post by kozikowski » Sun Mar 08, 2009 2:04 am
<<<I dont know what else to do? any suggestions?>>>
http://www.highcriteria.com/
Post by steve » Sun Mar 08, 2009 7:50 pm
stevethefiddle wrote:First make sure that the sound that you want to record is actually playing through the output sockets.
Did you check these two things?
Also, "Total Recorder" (which koz has suggested twice now) is a software solution to the problem.
anatomy1
Post by anatomy1 » Mon May 18, 2009 12:16 am
hey, sorry for such a late reply i thought the problem would never be solved. I was skeptical about purchasing Total Recorder...but I ended up shelling out and now my problems are solved. Many thanks to you guys, great help!
