removing voice track
jackson75
Post by jackson75 » Wed Feb 25, 2009 3:35 pm
I tried removing the voice track to make a karaoke recording, and it worked great...however now every recording I play on my computer, the voice track sounds like its in a tunnel. (this is without Audacity enabled). I've looked everywhere to see if I had something set for reverb or any other effect..to no avail...any ideas how to correct??
Re: removing voice track
Post by kozikowski » Wed Feb 25, 2009 3:41 pm
Did you get new speakers? The Vocal Removal tools don't permanently change your machine, however, your speakers could be mis-wired and you're just now paying attention.
Play the Left-Right sound clip from here...
http://www.kozco.com/tech/soundtests.html
...and make sure only the last segment sounds weird.
jackson75
Post by jackson75 » Wed Feb 25, 2009 9:36 pm
That's just it...nothing was changed. I used audacity to remove the voice track on one number, and after exiting audacity all music had a problem... I tried restoring to a prior date.... (Before working with audacity) but that didn't work...I'm completely baffled..
Post by kozikowski » Wed Feb 25, 2009 10:46 pm
<<<I'm completely baffled..>>>
But not baffled enough to try that sound track...
jackson75
Post by jackson75 » Thu Feb 26, 2009 1:41 pm
KOZ
Sorry, I apologize...I didn't notice the link to the test....I tried it and on "3" it sounded like it was in a tunnel... I assume that means my system is operating correctly and maybe it's just my hearing??
