Sir Steve-
May a thousand camels grace your caravan! I get sound now. Only one problem.....I put one guitar track down. When I try to put another on and play it back after recording, the two tracks are not in sync. The first track is about 1/2 second earlier than the first. Is there some kinda sync button somewhere I have missed?
Ahhh...Reel to reel
no signal when recording original music
Re: no signal when recording original music
Audacity 1.3 has those. Not 1.2. You can have both versions on your machine as long as you actually use only one at a time.
You are listening to the latency of your computer. That's what one round trip through your computer sounds like. Every time the computer has to stop and think a second, you lose on Sports Call®.
The patch job involves selecting and sliding your new performance back into sync and then record yet another, slide, etc.
Or go use 1.3.
Or go use 1.3.
Apart from that sentence not making sense, 1/2 second sounds like more than a latency problem. My suspician is that you have switched on "software playthrough" in Audacity's preferences (Audio I/O tab). "Software playthrough" should not be selected.earlybird wrote:The first track is about 1/2 second earlier than the first.
