Backtrack doesn't play when I press ''Record''
ride450
Post by ride450 » Mon Feb 23, 2009 2:52 am
I am trying to record a vocal track along with an existing instrumental. When I press play the instrumental plays fine but when I press Record, instead of the instrumental playing along there is no sound whatsoever... It used to work but this problem just started occuring.. I am using the non-beta version. Thanks!!
allencmcbride
Re: Backtrack doesn't play when I press ''Record''
Post by allencmcbride » Mon Feb 23, 2009 3:11 am
You may already have tried this, but under the "Audio I/O" tab in the Preferences, there is a checkbox for "Play other tracks while recording new one". Make sure it's checked. If it's already checked, I won't know how to help you, but I'm sure someone else here will. --Allen
Post by kozikowski » Mon Feb 23, 2009 3:12 am
The settings for that are all crammed into..
Edit > Preferences > Audio I/O > Stuff On The Bottom.
ride450
Post by ride450 » Mon Mar 02, 2009 8:07 am
Thanks guys, that did the trick :)
