recording for voicemail
djarcadian
I have a recording I'm going to use for a voicemail greeting. The system I'm using it with (Ringcentral.com) says it needs to be in either CCITT u-Law (G711a), 8kHz, 8 bit, mono (recommended) or PCM, 8kHz, 16 bit, mono formats. I'd prefer to do the former since it's recommended but if I need to do the later so be it. I was able to switch to 16-bit but when I bumped it down to 8kHz it becomes very slow. How can I fix this so it works correctly?
djarcadian
Re: recording for voicemail
Okay, I figured out the Project Rate is in the lower left hand corner. What does it mean by PCM?
"Pulse Coded Modulation", but you don't need to know that.
Just export it as a (Microsoft) WAV file.
With Audacity 1.3 you can export as u-law. I'm not sure if it is exactly the right format, but u-law is listed in the "Other Uncompressed Formats" as an option for (Microsoft) WAV.
