Error while opening sound device......
Max Torrens
Post by Max Torrens » Mon Feb 16, 2009 12:08 am
I am being driven crazy by the error message "Error while opening sound device. Please check the input settings and the project sample rate."
I use Windows XP SP3 and have been recording with Audacity 1.2 for three years or so very well. But suddenly this message started coming (around 20th Jan 09) and I cannot solve the problem although I am sure I have checked everything. Using Realtek audio driver. I cannot think of any download to my system that would have interfered with Audacity, though I suppose this must be possible.
Can anyone help me out on this, please? I see from the forum that this problem has vexed people before me!
Max
Re: Error while opening sound device......
Post by kozikowski » Mon Feb 16, 2009 5:22 am
<<<I see from the forum that this problem has vexed people before me!>>>
Then you'll also see that the first thing we ask them is, "What are you recording from?"
Microphone plugged into the Mic-In of the sound card?
Max Torrens
Post by Max Torrens » Mon Feb 16, 2009 7:35 am
I'm sorry I should have said. I am recording from the radio. In other words, everything is internal. I do not use external input at all. But I have tried a microphone in the mic jack and I still get the error message. Does that focus it down for you?
Max
Post by steve » Mon Feb 16, 2009 3:37 pm
Max Torrens wrote:In other words, everything is internal
So you are wanting to record from "Stereo Mix".
We need to look at relevant settings for the sound system, including settings that are not in Audacity.
Do you know how to access your Realtek sound card control panel? (loudspeaker icon near the clock)
Are you familiar with what all of the settings in there are for?
In Audacity, what are the options in "Edit menu > Preferences > Audio I/O" for "recording device" and "playback device"?
Which options do you have selected?
In Audacity, what are the options in "Edit menu > Preferences > Quality" What do you have set for the default sample rate and bit depth?
Can you record with the Microsoft Sound Recorder?
What do you have set in the "Windows Control Panel > Sounds and Audio Devices" as the default recording and playback devices?
Max Torrens
Post by Max Torrens » Mon Feb 16, 2009 5:38 pm
Thank you for your reply. The answer to your questions are:
Yes
stevethefiddle wrote:We need to look at relevant settings for the sound system, including settings that are not in Audacity.
I think so. I have visited them many times.
stevethefiddle wrote:In Audacity, what are the options in "Edit menu > Preferences > Audio I/O" for "recording device" and "playback device"?
Both are Realtek
stevethefiddle wrote:In Audacity, what are the options in "Edit menu > Preferences > Quality" What do you have set for the default sample rate and bit depth?
44100Hz; 32-bit rate
stevethefiddle wrote:Can you record with the Microsoft Sound Recorder?
Yes, with microphone. But I cannot record the radio from the internet.
stevethefiddle wrote:What do you have set in the "Windows Control Panel > Sounds and Audio Devices" as the default recording and playback devices?
Realteck AC97.
Post by steve » Mon Feb 16, 2009 11:48 pm
Try changing the recording and playback to "Microsoft Sound Mapper".
Restart Audacity so that the changes take effect.
To record "Stereo Mix" you need to set that as the recording source in the Realtek sound card control panel.
Max Torrens
Post by Max Torrens » Tue Feb 17, 2009 9:24 am
Eureka! Those changes did not work on their own but I noticed that the number of channels was set to 4 - God knows how or why. But when I moved this to 2, all was fine.
So, Mr Steve the Fiddle, whoever you may be and wherever you are, many grateful thanks for helping me.
Max (SW England)
