Hi all!
I need to do a "bouncing" (left to right) pan effect to a single stereo track. How do I accomplish that?
Thanks!
How to do the bouncing pan effect in a single track?
riccaliolio
Re: How to do the bouncing pan effect in a single track?
You first need to turn the track into a stereo track.
See here: http://audacityteam.org/forum/viewtopic.php?f=27&t=8658
riccaliolio
Thanks for the info. Then how to get the pan effect?stevethefiddle wrote:You first need to turn the track into a stereo track.
I think there is a plug-in available. Have a look here: http://audacityteam.org/download/plugins
I do not really recommend VST plug-ins as they are only partially supported and can cause major headaches, so go for LADSPA or Nyquist plug-ins.
