Recording at 24bit appears to be 16 bits padded to 24bit
Re: Recording at 24bit appears to be 16 bits padded to 24bit
i was in 24 bit depth.
linear goes from nearly 1 to zero
thatzzalottadeebees!
the db scale only shows a range of about 24 db
clearly i am missing something here that was not explicitly stated
does the display average over the last n samples?
Linear goes from +1.0 to -1.0whomper wrote:linear goes from nearly 1 to zero
The linear scale relates to the numerical value of the samples.
As I wrote in an earlier post in this thread;whomper wrote:the db scale only shows a range of about 24 db
<<< The bottom end of the dB scale can be set by the user "Edit > Preferences > Interface" >>>
i have the bottom set
audacity does not seem to use it though
just a small part of the top
- Quality Assurance
Are you zooming in vertically?whomper wrote:i have the bottom set audacity does not seem to use it though just a small part of the top
If not, please post an image of what you mean.
i zoom in at times to get more resolution at the top
Resurrecting an old thread...
Just wondering if this issue with Audacity recording 24 bits (on Windows platforms) is still actually 16 bits (padded with zeros in the 8 lsbs) to 24 bits due to a limitation in Portaudio has been fixed?
Terry
Terry
- Quality Assurance
No - http://wiki.audacityteam.org/wiki/Relea ... _RecordingTerry wrote:Just wondering if this issue with Audacity recording 24 bits (on Windows platforms) is still actually 16 bits (padded with zeros in the 8 lsbs) to 24 bits due to a limitation in Portaudio has been fixed?
Thanks for the quick reply.
Any chance it will be fixed?
Terry
Terry
- Quality Assurance
Not until after Audacity 2.0, and even then, the one Audacity developer who expressed an interest in it isn't active any longer.Terry wrote:Any chance it will be fixed?
If you are really concerned you could join the PortAudio mailing list and ask them directly about this restriction. If they fixed it we would consider updating our version of PortAudio, depending on when we thought it was safe.
Or you could try Linux. Ubuntu or PCLinux are usually thought of as "easy" OS'es to learn for Windows users.
