That's great news!eharmonica wrote:They both look fine to me. And yes, I'm jealous. Could you tell us what your settings are?thunderstick wrote:Alright then...totally raw recordings....
This one was produced with MME: MME FILE
This one was produced with DirectSound: Direct Sound FILE
I (very) anxiously await your test results
I just arrived back here to post the new files I made (as you suggested with the in-between track silence)...guess I don't need to post the links? Well, here are 2 new ones I created for you anyhow (if they are in any way more precise to work with): MME Device & DirectSound Device
I'm not sure why you'd be jealous, if CEP works for you I'd be happy too. The one main reason I like using Audacity, aside from its simplicity, is the fact you don't install anything. I've been doing quite a bit of reading on both the Audacity forums and in others, and I wonder if infact drivers do not play a crucial part with regards to this problem, perhaps?
Aside from that, with regards to my settings, which ones would you like to know? As you're well aware, there really are but only a few that need configuring. I can see only Device and Project Rate, really. Let me know and I'll surely tell you.
But I do want to say thanks very much for testing my files. It would be an absolute nightmare to have to re-rip all the vinyl I've done so far, so, so many hours of time invested....ugh.
I had CEP queued up for installation had your report been negative, so again, eharmonica, I am grateful for your assistance in processing my files.
