Audio file skips after being converted with Switch!
saltydeath
I have an Olympus VN-4100 PC recorder. I recorded some files in mp3, then used Switch audio to convert them to .AIFF so I could open them in Audacity. When I played the file in Audacity they skipped a lot, which they never did before the conversion. How do I fix this?
Re: Audio file skips after being converted with Switch!
<<<I recorded some files in mp3>>>
Maybe not since the Olympus produces work in the CELP+ADPCM format. According to the instructions, this machine will record 144 hours of work on 256MB of memory. MP3 won't do that. So your real job is finding a software package that can convert CELP+ADPCM to AIFF or WAV.
