Please, teach me how to do.
Transferring LP:s fails
musikalskare
waxcylinder
Re: Transferring LP:s fails
musikalskare
Audacity's Mixer Toolbar's input selector, where do I find this?
Furthermore, I would like to have both options - listen and not listen - when recording.
As you understand of my questions I'm not very good with computers but I'm very happy there are pros.
To select the desired input in Audacity, go to the Edit menu and select "Preferences". When the Preferences window opens, look at the top of the "Audio I/O" tab and you will see two drop down boxes, one for the recording device, and one for the playback device. If your turntable is a USB turntable, then select the USB option for the recording device, and select one of the Creative/SoundBlaster options for the playback device (you may need to experiment a little to see which option works).
To be able to hear the USB turntable while recording, you need to select "software playthrough" in the Audacity Preferences (also on the Audio I/O tab).
musikalskare
Thank you for your assistance. Now everything is working as expected.
