I reformatted my computer yesterday and before that I've never had a problem with Audacity, I use it for all band recordings. But then I reformat my computer and download the new beta.... here's the problem.
At first there seemed to be no sound coming form the recording, but when I played the recording it sounded fine. I went into preferences and clicked Software Playthough and then it started playing it.
The weird thing is before I could open audacity, select line in and it would play audio from my guitar regardless if I had the program open, but now it only plays strictly when I'm recording.
And not only that is the problem, but now there's like a second latency. All that was a real piss off so I uninstalled the Beta and went back to normal Audacity.... same problem.
All I did was reformat my computer, I never found a need to go into preferences before or adjust any options. The thing's plugged into my Line-in jack and it's never left the jack since I've put it in. And yes I tried unplugging it and unplugging it.
