Jim B
Post
by Jim B » Sun Jan 25, 2009 1:49 pm
Hi
I've download Audacity a couple of days ago, been playing around with it and I quite enjoy it. Today I've been trying to record some old vinyl 12" records. The recording is fine, but when I try to save the file I get a message saying something like this
"non-activated version so voice logo will be added to output files?"
I using Version 1.2.6 and Vista OS. What do I need to do to clear this message, do I need to buy/donate in order to get a serial number to activate this part of the program
Jim B
Post
by Jim B » Sun Jan 25, 2009 7:03 pm
Or do I have to register the software, if so how
Any help will do, it's starting to Pee me off
- Site Admin
Post
by steve » Sun Jan 25, 2009 7:38 pm
Take care to either allow the automatic download or to use the actual Audacity download link and not one of the advertisements (unless you are interested in one of the advertised products of course).
gemo1234
Post
by gemo1234 » Fri Mar 27, 2009 6:57 pm
I've had the same problem, should I re-install it? so annyoing because its perfect other than that
- Site Admin
Post
by steve » Sun Mar 29, 2009 10:14 pm
gemo1234 wrote:I've had the same problem, should I re-install it? so annyoing because its perfect other than that
As said previously - Audacity does NOT require registering or "activation.
If your program does require this, then it is not the genuine "Audacity".
Many Vista users recommend Audacity 1.3
I would recommend it for all platforms.
