Whenever I open the AVS Audio Editor program, this little balloon pop up that says, "Thank you for evaluating AVS4YOU Software! This is a non-activated version. " Then when I save something and open it for anything, it says, "AVS Media Den" DURING whatever I'm doing!
Say that I'm saying in the mic, "Hey, how are you?" I save it, and open it again. Then it says, "AVS Media Den are you?" It's annoying and I am an animator, so I need to put voices to characters. Someone please help me! <8|
-Kat
I need help!
Re: I need help!
You have an evaluation copy of the AVS editor. You should write them a check and they will give you a license key.
Audacity doesn't do any of those things.
