sorahl
Post
by sorahl » Fri Jan 23, 2009 4:04 am
I'm running the stable version (or trying to).
I did a search but everyone else seems to crash later in the process
I can't even it to load!
i click on the icon or load from my programs menu and it crashes immediately.
what more can i tell you? (running as admin, tried to run in XP compat mode, etc etc)
John
sorahl
Post
by sorahl » Fri Jan 23, 2009 4:06 am
the crash problem details
Problem signature:
Problem Event Name: APPCRASH
Application Name: audacity.exe
Application Version: 0.0.0.0
Application Timestamp: 455814e4
Fault Module Name: audacity.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 455814e4
Exception Code: c0000005
Exception Offset: 0000b7ec
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: d26c
Additional Information 2: 7365c7ccbd7d104721855c6b081ebe0f
Additional Information 3: 6c5d
Additional Information 4: 9b5524c102c76b32431e108e44aead02
sorahl
Post
by sorahl » Fri Jan 23, 2009 4:12 am
also want to add that i tried the beta, it does RUN but has a problem with my input for some reason.
removed it, put stable back on... it crashes.
John
- Site Admin
Post
by steve » Fri Jan 23, 2009 1:48 pm
I think that you will have more success at fixing the Audacity 1.3 problems than fixing the Audacity 1.2 problems. (Audacity 1.2 pre-dates Vista SP1 and is no longer being developed).
Have another go with Audacity 1.3.6 (if you have an earlier version of 1.3, then download a new copy - Audacity 1.3.7 will be out very soon, so grab that as soon as it is available).
If you still have a problem, start a new topic in the "Audacity 1.3.x > Windows" section of the forum.
