Shortcut keys
wewe
Shortcut keys
Post by wewe » Wed Jan 21, 2009 1:23 pm
Hey Audacity,
Could you please give me the command line so I can bind effects utility Time line changer Reverse to a key other than, Ctrl+r
I what to use more than one function under effects and I have to keep clicking with the mouse, which makes it somewhat an inconvenience, do you have the code to bind GVerb as well, something else I tend to use a bit too,
thanks.
Re: Shortcut keys
Post by steve » Wed Jan 21, 2009 8:20 pm
Ctrl+R is the short-cut key combination for "Repeat last Effect".
It is not possible to bind keys to effects.
This is the full list of available bindings in Audacity 1.3.7 (you can access the list in "Preferences").
"New" ="New" key="Ctrl+N"
"Open" ="Open..." key="Ctrl+O"
"Close" ="Close" key="Ctrl+W"
"Save" ="Save Project" key="Ctrl+S"
"SaveAs" ="Save Project As..." key=
"SaveCompressed" ="Save Compressed Copy of Project..." key=
"CheckDeps" ="Check Dependencies..." key=
"EditMetaData" ="Open Metadata Editor..." key=
"ImportAudio" ="Audio..." key="Ctrl+Shift+I"
"ImportLabels" ="Labels..." key=
"ImportMIDI" ="MIDI..." key=
"ImportRaw" ="Raw Data..." key=
"Export" ="Export..." key=
"ExportSel" ="Export Selection..." key=
"ExportLabels" ="Export Labels..." key=
"ExportMultiple" ="Export Multiple..." key=
"ExportMIDI" ="Export MIDI..." key=
"AppplyChain" ="Apply Chain..." key=
"EditChains" ="Edit Chains..." key=
"PageSetup" ="Page Setup..." key=
"Print" ="Print..." key=
"Exit" ="Exit" key="Ctrl+Q"
"Undo" ="Can't Undo" key="Ctrl+Z"
"Redo" ="Can't Redo" key="Ctrl+Shift+Z"
"Cut" ="Cut" key="Ctrl+X"
"SplitCut" ="Split Cut" key="Ctrl+Alt+X"
"Copy" ="Copy" key="Ctrl+C"
"Paste" ="Paste" key="Ctrl+V"
"Trim" ="Trim" key="Ctrl+T"
"Delete" ="Delete" key="Ctrl+K"
"SplitDelete" ="Split Delete" key="Ctrl+Alt+K"
"Silence" ="Silence Audio" key="Ctrl+L"
"Split" ="Split" key="Ctrl+I"
"SplitNew" ="Split New" key="Ctrl+Alt+I"
"Join" ="Join" key="Ctrl+J"
"Disjoin" ="Detach at Silences" key="Ctrl+Alt+J"
"Duplicate" ="Duplicate" key="Ctrl+D"
"CutLabels" ="Cut" key="Alt+X"
"SplitCutLabels" ="Split Cut" key="Shift+Alt+X"
"CopyLabels" ="Copy" key="Shift+Alt+C"
"DeleteLabels" ="Delete" key="Alt+K"
"SplitDeleteLabels" ="Split Delete" key="Shift+Alt+K"
"SilenceLabels" ="Silence" key="Alt+L"
"SplitLabels" ="Split" key="Alt+I"
"JoinLabels" ="Join" key="Alt+J"
"DisjoinLabels" ="Detach at Silences" key="Shift+Alt+J"
"SelectAll" ="All" key="Ctrl+A"
"SelectNone" ="None" key="Ctrl+Shift+A"
"SetLeftSelection" ="Left at Playback Position" key="["
"SetRightSelection" ="Right at Playback Position" key="]"
"SelStartCursor" ="Track Start to Cursor" key="Shift+J"
"SelCursorEnd" ="Cursor to Track End" key="Shift+K"
"ZeroCross" ="Find Zero Crossings" key="Z"
"CursSelStart" ="to Selection Start" key=
"CursSelEnd" ="to Selection End" key=
"CursTrackStart" ="to Track Start" key="J"
"CursTrackEnd" ="to Track End" key="K"
"SelSave" ="Region Save" key=
"SelRestore" ="Region Restore" key=
"LockPlayRegion" ="Lock" key=
"UnlockPlayRegion" ="Unlock" key=
"Preferences" ="Preferences..." key="Ctrl+P"
"ZoomIn" ="Zoom In" key="Ctrl+1"
"ZoomNormal" ="Zoom Normal" key="Ctrl+2"
"ZoomOut" ="Zoom Out" key="Ctrl+3"
"FitInWindow" ="Fit in Window" key="Ctrl+F"
"FitV" ="Fit Vertically" key="Ctrl+Shift+F"
"ZoomSel" ="Zoom to Selection" key="Ctrl+E"
"CollapseAllTracks" ="Collapse All Tracks" key="Ctrl+Shift+C"
"ExpandAllTracks" ="Expand All Tracks" key="Ctrl+Shift+X"
"ShowClipping" ="Show Clipping" key=
"UndoHistory" ="History..." key=
"ShowControlTB" ="Control Toolbar" key=
"ShowDeviceTB" ="Device Toolbar" key=
"ShowEditTB" ="Edit Toolbar" key=
"ShowMeterTB" ="Meter Toolbar" key=
"ShowMixerTB" ="Mixer Toolbar" key=
"ShowSelectionTB" ="Selection Toolbar" key=
"ShowToolsTB" ="Tools Toolbar" key=
"ShowTranscriptionTB" ="Transcription Toolbar" key=
"ResetToolbars" ="Reset Toolbars" key=
"Play" ="Play" key="Space"
"PlayLooped" ="Loop Play" key="Shift+Space"
"Pause" ="Pause" key="P"
"Stop" ="Stop" key="Space"
"SkipStart" ="Skip to Start" key="Home"
"SkipEnd" ="Skip to End" key="End"
"Record" ="Record" key="R"
"TimerRecord" ="Timer Record..." key="Shift+T"
"RecordAppend" ="Append Record" key="Shift+R"
"Duplex" ="Overdub (on/off)" key=
"SWPlaythrough" ="Software Playthrough (on/off)" key=
"SoundActivation" ="Sound Activated Recording (on/off)" key=
"SoundActivationLevel" ="Sound Activation Level..." key=
"NewAudioTrack" ="Audio Track" key="Ctrl+Shift+N"
"NewStereoTrack" ="Stereo Track" key=
"NewLabelTrack" =" Track" key=
"NewTimeTrack" ="Time Track" key=
"Stereo to Mono" ="Stereo Track to Mono" key=
"MixAndRender" ="Mix and Render" key=
"MixAndRenderToNewTrack" ="Mix and Render to New Track" key="Ctrl+Shift+M"
"Resample" ="Resample..." key=
"RemoveTracks" ="Remove Tracks" key=
"MuteAllTracks" ="Mute All Tracks" key="Ctrl+U"
"UnMuteAllTracks" ="UnMute All Tracks" key="Ctrl+Shift+U"
"StickyLabels" ="Link Audio and Tracks" key=
"AddLabel" ="Add At Selection" key="Ctrl+B"
"AddLabelPlaying" ="Add At Playback Position" key="Ctrl+M"
"EditLabels" ="Edit Labels" key=
"SortByTime" ="by Start time" key=
"SortByName" ="by Name" key=
"RepeatLastEffect" ="Repeat Last Effect" key="Ctrl+R"
"PlotSpectrum" ="Plot Spectrum..." key=
"About" ="About Audacity..." key=
"Welcome" ="Show Welcome Message..." key=
"Help" ="Index..." key=
"Log" ="Show Log..." key=
"Benchmark" ="Run Benchmark..." key=
"DeviceInfo" ="Audio Device Info..." key=
"PrevFrame" ="Cycle backward through toolbars and Track View" key="Ctrl+Shift+F6"
"NextFrame" ="Cycle forward through toolbars and Track View" key="Ctrl+F6"
"SelectTool" ="Selection Tool" key="F1"
"EnvelopeTool" ="Envelope Tool" key="F2"
"DrawTool" ="Draw Tool" key="F3"
"ZoomTool" ="Zoom Tool" key="F4"
"TimeShiftTool" ="Time Shift Tool" key="F5"
"MultiTool" ="Multi Tool" key="F6"
"NextTool" ="Next Tool" key="D"
"PrevTool" ="Previous Tool" key="A"
"Play/Stop" ="Play/Stop" key="Space"
"Stop" ="Stop" key="S"
"RecordAppend" ="Record Append" key="Shift+R"
"PlayStopSelect" ="Play/Stop and Set Cursor" key="Shift+A"
"PlayOneSec" ="Play One Second" key="1"
"PlayToSelection" ="Play To Selection" key="B"
"PlayLooped" ="Play Looped" key="L"
"PlayLoopAlt" ="Play Looped" key="Shift+Space"
"PlayCutPreview" ="Play Cut Preview" key="C"
"SelStart" ="Selection to Start" key="Shift+Home"
"SelEnd" ="Selection to End" key="Shift+End"
"DeleteKey" ="DeleteKey" key="Backspace"
"DeleteKey2" ="DeleteKey2" key="Delete"
"SeekLeftShort" ="Seek left short period during playback" key="Left"
"SeekRightShort" ="Seek right short period during playback" key="Right"
"SeekLeftLong" ="Seek left long period during playback" key="Shift+Left"
"SeekRightLong" ="Seek right long period during playback" key="Shift+Right"
"PrevTrack" ="Move Focus to Previous Track" key="Up"
"ShiftUp" ="Move Focus to Previous and Change Selection" key="Shift+Up"
"NextTrack" ="Move Focus to Next Track" key="Down"
"ShiftDown" ="Move Focus to Next and Change Selection" key="Shift+Down"
"Toggle" ="Toggle Focused Track" key="Return"
"Toggle1" ="Toggle Focused Track" key="NUMPAD_ENTER"
"Toggle2" ="Toggle Focused Track" key="Ctrl+Space"
"CursorLeft" ="Cursor Left" key="Left"
"CursorRight" ="Cursor Right" key="Right"
"CursorShortJumpLeft" ="Cursor Short Jump Left" key=","
"CursorShortJumpRight" ="Cursor Short Jump Right" key="."
"CursorLongJumpLeft" ="Cursor Long Jump Left" key="Shift+,"
"CursorLongJumpRight" ="Cursor Long Jump Right" key="Shift+."
"SelExtLeft" ="Selection Extend Left" key="Shift+Left"
"SelExtRight" ="Selection Extend Right" key="Shift+Right"
"SelSetExtLeft" ="Set (or Extend) Left Selection" key=
"SelSetExtRight" ="Set (or Extend) Right Selection" key=
"SelCntrLeft" ="Selection Contract Left" key="Ctrl+Shift+Right"
"SelCntrRight" ="Selection Contract Right" key="Ctrl+Shift+Left"
"TrackPan" ="Change pan on focused track" key="Shift+P"
"TrackPanLeft" ="Pan left on focused track" key="Alt+Shift+Left"
"TrackPanRight" ="Pan right on focused track" key="Alt+Shift+Right"
"TrackGain" ="Change gain on focused track" key="Shift+G"
"TrackGainInc" ="Increase gain on focused track" key="Alt+Shift+Up"
"TrackGainDec" ="Decrease gain on focused track" key="Alt+Shift+Down"
"TrackMenu" ="Open menu on focused track" key="Shift+M"
"TrackMute" ="Mute/Unmute focused track" key="Shift+U"
"TrackSolo" ="Solo/Unsolo focused track" key="Shift+S"
"TrackClose" ="Close focused track" key="Shift+C"
"SnapToOn" ="Snap To On" key=
"SnapToOff" ="Snap To Off" key=
"FullScreenOnOff" ="Full screen on/off" key="F11"
wewe
Re: Shortcut keys
Post by wewe » Thu Jan 22, 2009 7:02 am
So why is it not possible, can you show me the codes of effects. What are the command names of Effects, they each have to have command names.
Or am I misunderstanding something here, how have you coded it.
Re: Shortcut keys
Post by steve » Thu Jan 22, 2009 5:41 pm
wewe wrote:So why is it not possible, can you show me the codes of effects.
I'm just a well seasoned user of Audacity, not a developer, so I can tell you much about what Audacity does, but not much about how it does it. I think they use some deep kind of magic.
If you understand about coding stuff, the code is available here for you to examine: http://audacityteam.org/latest/audacity ... 2.6.tar.gz
I can see potential pitfalls with trying to support bindings to effects as they exist as plug-ins. Audacity supports plug-ins in various formats, and there are thousands of plug-ins available. Enabling key bindings to plug-ins would probably open up thousands of opportunities for users to break Audacity by passing invalid parameters to the plug-ins. As the plug-ins are mostly created by third parties, there is no way that Audacity could know what parameters are valid, and what are not.
If you are interested in developing Audacity, you should look to the 1.3 version as 1.2 development ended a long time ago, and current development is toward the new 1.4 version. See the Audacity wiki for more information: http://audacityteam.org/wiki/index.php? ... _Home_Page
