Startup folder
Startup folder
Every time I start V1.2.6, it always directs me to the windows/system 32 folder..never my music folder or even desktop. Is there anyway to set it so it opens my music folder as default?
Re: Startup folder
I presume that you mean when you use "Open" or "Import".
Upgrade to Audacity 1.3 - the default directory is automatically set to whichever directory you used last.
Re: Startup folder
Exactly. Thx, will give it a try.
stevethefiddle wrote:I presume that you mean when you use "Open" or "Import".
