Hello everyone, I'm new to the forum. I was hoping someone could help me with this program.
I used to be able to just play a video on say, Windows Media or VLC player, and be able to record just the audio using Audacity. Then I would use the Lame program to convert the audio to Mp3 format, but now I cannot do that anymore. The dropbox that used to allow me to record from my microphone/Wave-in/etc. no longer functions. Can anyone help me?
Thanks in advance,
Zac ([email protected])
Recording audio from a video
Re: Recording audio from a video
You need to set the Windows Mixer, or your sound card control panel to record from "Stereo Mix".
See here for details: http://audacityteam.org/wiki/index.php? ... e_computer
If you are on Vista, also see see here: http://audacityteam.org/wiki/index.php? ... s_Vista_OS
That's the problem I'm having though, I can't select anything from that dropdown box, it won't let me pick anything, its just blank. Or am I thinking of something else? Sorry, this is giving me such a hard time, I used to be good at using this program.
If you find struggling with Windows becoming a career move, you can use Total Recorder to easily record anything moving through your PC.
http://www.highcriteria.com/
A Happy User
A Happy User
The "drop down box"? I bet you are still looking in Audacity for the problem/solution, but the issue is not there - the issue is with setting up the computer sound system.Cless wrote:I can't select anything from that dropdown box
Audacity can sometimes talk to the sound card and tell the sound card which input it wants to access, but that is entirely dependent on whether the sound card drivers will allow Audacity to do so, and on modern computers this is often not the case, in which case you need to speak to the sound card driver directly. This is done either, through the Windows Mixer (look for a loudspeaker icon near the computer clock) or through the sound cards control panel (look for an icon near the clock) or failing either of hose, through the Windows Control Panel.
See the links that I posted for more details.
