Once more hello,
So, I 'm out of my problem.
I tried with the 2 cables reduced to a mini jack. It worked but the recordlevel
was much to high. Looking how to solve it I came to the settings of my audiocard.
There I saw that it was set on 1 channel / 16000 bit.
I changed it into 2 channels 44000 bit ( cd quality ).
Now everything works as espected. I feel a bit ???.
Maybee someone has the same problem in the future so I hope
this will be usefull.
In attachement a Prt Scr of the settings.
As you can see the 2 channels are not the same now.
Anyway thanks a lot for your help.
STEREO
waxcylinder
Re: STEREO
Glad you got it working properly at last - and thanks for posting your solution - as you say it may help others in the future.
