Vocal Track Playback NOT IN TIME
RemiJ
Post by RemiJ » Fri Jan 02, 2009 3:38 am
Hi, alright so Audacity used to work perfect for me until suddenly the vocal track I would record over the instrumental track would start going faster and not in time. It's been like this for 2 years now and I've never been able to fix it unfortunatley. Does anyone know why it's speeding up?
Re: Vocal Track Playback NOT IN TIME
Post by kozikowski » Fri Jan 02, 2009 5:42 am
Did it start doing this about the time you bought a new computer or sound card?
RemiJ
Post by RemiJ » Sun Jan 04, 2009 5:59 am
No, jsut randomly one day I recorded, played it back, and it was speeding up and not in time with the imported instrumental track. :?
Post by steve » Sun Jan 04, 2009 1:36 pm
Try using a different sample rate (Edit > Preferences > Quality).
Some sound cards will play up with some sample rates - the recommended sample rates are 44100Hz and 48000Hz - try both.
If that does not help, it could be that your sound card has developed a fault. Another possibility is that an update to the drivers has caused a problem, so you could look to see if the driver can be rolled back to an earlier version.
