alandelder
Post by alandelder » Mon Dec 29, 2008 1:50 pm
I installed Audacity1.2.6 on Windows XP yesterday afternoon. It worked perfectly. Today when I switched it on all letters are appearing as"?", so that file for example appears as ???? and preferences is ???????????. How can I get the proper words back? Can anyone please help.
Thanks
waxcylinder
Re: ???????
Post by waxcylinder » Mon Dec 29, 2008 2:44 pm
To change the language use: Edit>Preferences - Edit is the second command in from top left, then Preferences is the bottom selection in the drop-down list.
Then you need the Interface tab, which is the third one in from the right.
Language is selected from the only drop-down list in the dialogue box - use this to change to English.
alandelder
Re: ???????
Post by alandelder » Mon Dec 29, 2008 4:06 pm
Many thanks for your help. All is "hunky dory" now. :D
