Ogg Vorbis import problem
yobar23
Post by yobar23 » Sat Dec 27, 2008 6:05 am
I've got a 40 minute album in Ogg Vorbis format and want to cut out a single track as a single file. I click File|Open the .ogg and see an Import box pop up letting me know it's importing the .ogg, but I only get the first 2 minutes of the file, which coincides with the length of the first tune. Same thing happens when I try Project|Import Audio. I've used Audacity with much larger .wav and .mp3 files and have never had a problem opening and/or editing them. Any ideas about my problem? I read the manual and found this sentence on page 5:
"Audacity works with tracks, that contain one audio file."
It's a single .ogg file, but with 11 separate tunes. Does that break the Rules of Audacity? I'm bumming. :x
I run Audacity 1.2.6 under WinXP SP3
An rud a scríobhann an púca, léann sé féin é
Re: Ogg Vorbis import problem
Post by steve » Sun Dec 28, 2008 4:16 am
What program was the ogg file created with?
Does the file play correctly? If so, in what player?
Perhaps you can convert the file into a WAV file with SUPER or FooBar 2000, then import the WAV file into Audacity.
