- Quality Assurance
Post
by Gale Andrews » Sat Dec 27, 2008 7:57 am
Tecno37 wrote:I have been buringing continuous mixes with no prob, and I could try exporting the track info as you stated. Except this would still not give me functional breaks interms of the CD player reading the disc (this is right isn't it).
No. The cue sheet will instruct the CD burner to create separate tracks. DAO is essential so that the burner does not turn off and on between burning the tracks.
Tecno37 wrote:So I'll have to re-author the content, putting individual track breaks in and burning track by track with a gapless setting.
I would not, for the reasons stated. While proper software and hardware will make a DAO gapless CD from multiple files, you have a better chance burning from one file.
Tecno37
Post
by Tecno37 » Sat Dec 27, 2008 11:09 am
will try and let you know
thanks for your time on this one
- Site Admin
Post
by steve » Sun Dec 28, 2008 4:08 am
Nero can do gap-less CD tracks very easily - I think all versions of Nero can do this, even the cheap "Nero Essentials" (but if you are going to buy it, check that it can before you buy).
Tecno37
Post
by Tecno37 » Sun Dec 28, 2008 5:00 am
grr now I can't get Nero to recognise the burner!
It is recognised in Media Player's burning suite
it won't even bring the 'autodetect' wizard up
anyideas?
cheers
- Site Admin
Post
by steve » Sun Dec 28, 2008 5:14 am
Check that your CD burner is physically connected correctly.
Check that the drivers are correctly installed.
Are you logged on as an Administrator? if not, then you need to make CD burning available to non-administrative accounts, which can be done using Nero burn rights (
http://www.nero.com/enu/support-nero6-t ... ities.html )
Tecno37
Post
by Tecno37 » Sun Jan 11, 2009 12:16 am
YAY!
I just got EVERYTHING to work with Gapless burning VIA Nero 8. Thanks to all who helped privide advice.
The mixtape doctor is in session!
Now I have some really rare audio from old DJ promos from the early 90s and late 80s on CD.
check it out at
http://www.discogs.com/release/510134
