I have a large mp3 file that contains 12 tracks that
are cross faded
My question is, how do I split this file into 12
separate mp3 files, without doing it manually ?
Removing cross fade
Re: Removing cross fade
You can set labels at appropriate places within the cross fade, then use "Export Multiple".
http://audacityteam.org/wiki/index.php? ... ate_tracks
You will not be able to "un-cross-fade" the ends of each piece.
