Can't hear while recording
Re: Can't hear while recording
Thanks to everyone who tried to help, 'ppreciate it.
Is your Mic turned On?? If not Turn your mixer On. If You have 1 OK. The only other thing I can tell you is check in your sound & Devices properties in Control Panel. & go to Voice & make sure it says RealTek AC97 & that should work it Does for me I hope this Helps you out
Tommy Benson
Tommy Benson
