Windows Export to AIFF Format
kristin
Post by kristin » Tue Nov 25, 2008 11:07 pm
Is it possible for Windows Audacity to export to AIFF? I've been exporting to WAV, but now I need AIFF format for a project. The documentation mentions this, but since this is an Apple format, I'm wondering if it's only in the Mac version. Can someone fill me in? Thanks
Re: Windows Export to AIFF Format
Post by steve » Wed Nov 26, 2008 12:57 am
Yes it can.
In Audacity 1.3.x it is very simple to change the Export format - you just select the options that you want in the Export dialogue.
kristin
Post by kristin » Fri Nov 28, 2008 10:42 pm
I see, once you change it in the preferences, it shows up in the File menu.
Thanks for your help.
Post by kozikowski » Sat Nov 29, 2008 2:23 am
What kind of project needs AIFF? Apple perfectly supports WAV in most if not all of its programs.
