Runtime Error on Install
count_brockula
Post by count_brockula » Tue Nov 25, 2008 7:41 pm
This is a new one on me. I have used Audacity for a few years now with no problems. I recently had to re-install Audacity and now when I install and try to run I get the following popup window:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Program FilesAudacityaudacity.exe
abnormal program termination
What's causing this and how can I fix it? I am in the middle of finishing the final mix of an album that has to be completed ASAP! I have never had this problem before. I have uninstalled and re-installed to no avail.
I am running WinXP Pro and Audacity 1.2.6
I am in panic mode here. HELP!!
Tnx,
dB
Re: Runtime Error on Install
Post by steve » Wed Nov 26, 2008 12:49 am
"Uninstalling" Audacity does not remove Audacities Preferences, so there is no "clean uninstall" until you manually remove Audacities preferences. Instructions for doing so are here: http://audacityteam.org/wiki/index.php? ... references
count_brockula
Post by count_brockula » Wed Nov 26, 2008 3:40 am
stevethefiddle wrote:"Uninstalling" Audacity does not remove Audacities Preferences, so there is no "clean uninstall" until you manually remove Audacities preferences. Instructions for doing so are here: http://audacityteam.org/wiki/index.php? ... references
Thanks for the tip, but I probably should have mentioned that I already did all of that. Didn't work. This problem occurred AFTER I did all of this and re-installing doesn't help. That is why I am so confused by the runtime error.
Post by steve » Wed Nov 26, 2008 4:05 am
Strange - can you do a system restore to a time when Audacity was working, and then reinstall?
