I have included a sample: http://www.sendspace.com/file/32j8st
It is only 135kb, so don't worry about it being a huge mp3 file
Keep in mind that when I play each track separately, they each sound clean with no problems.
Thanks, I appreciate it!
Thanks pal, it worked!! I don't have a lot of experience mixing things.. Thanks again!stevethefiddle wrote:Use the volume sliders on the left side of each of the tracks to lower the volume of each track. When you play two or more tracks at the same time, the sounds are added together, and can cause the resulting "mix" to be too loud and distort.
