A problem
ladyghost
A problem
Post by ladyghost » Tue Nov 18, 2008 9:58 am
I use Audacity since long time ago and I have never had this problem.
A friend of mine has sent me an aup audio file.
And Audacity says me it can't open it!
How can I pass it into mp3 now?
Ladyghost.
waxcylinder
Re: A problem
Post by waxcylinder » Tue Nov 18, 2008 11:40 am
A friend of yours should have sent you not just the aup file - but also the folder associated with it containing the hundreds of little au files that make up the Audacity project.
Better still would have been for your friend to export the project as a WAV file and then send the WAV file to you - can thay still do that?
