extend a MP3 with silence versus trim MP3
cees
Post by cees » Sun Nov 16, 2008 12:16 am
Dear sir,
I would like to add a few seconds of silence to the beginning and the end of my MP3 file. So far no problem in the Audacity program. When I press play, the extra seconds are added. But when I export to a new MP3 file, all of a sudden the extra seconds of silence at the beginning and end have disappeared. What do I do wrong?
Best regards, Cees
Re: extend a MP3 with silence versus trim MP3
Post by kozikowski » Sun Nov 16, 2008 1:38 am
How did you add the silence? Generate > Silence?
Audacity doesn't actually edit MP3 files. Few programs can. They convert it to editor native format, edit that, and then convert back. As a first pass, I would Edit > Select > All and try to export that.
Can you Export As WAV? A work-around would be to do that and then use that as the master to create the new MP3.
