Hopefully the community here can help,
I have a project that calls for me to generate several hundred unique audio tags and then combine them with an introduction. all in mp3 format!
My question: will audacity do this? can I setup a batch that will take each tag and combine it with the intro and render out to a separate file?
I have some audio editing experience, but I am a mostly a video editor. If this is not the right tool, can you recommend one? I do have "some" budget.
Thanks!
Thomster
batch process to combine 2 mp3's together
Re: batch process to combine 2 mp3's together
I got small pieces. I think Version 1.3.x has a "link" tool that will do batch. There is no batch process in 1.2.x.
thanks!
so the new version of audicity has a "link" tool that will stitch the 2 files together? I will give it a try, Does anyone know if i can batch that operation?
No, I think "Link" is the batch operation. I have no idea which tools can be included in the batch.
