Windows XP SP2
Dell 2000 mhz
768 RAM
Delta 44 Soundcard, driver 5.10.0.5065
Audactiy 1.2.6
I've checked the forums and the Wiki, and it seems I should have no problems recording 4 tracks - I realize that I won't have the option of choosing inputs for each track, but I can deal with that. I can successfully record when I select Delta 1/2 or Delta 3/4 or Delta Multi at two channels for my recording device, but that only gives me 2 tracks. When I select 4 tracks, I get the error described below.
I have my Delta driver and Audacity program both set at the same rates but I get this Error: Error while opening the sound device. Please check the input device settings and the project sample rate.
I saw in another thread that I should click on Help in Audacity then device settings, but in my Help my options are Contents and About, neither of which were helpful.
Any thoughts on what I can do here?
Recording 4 Channels at Once - Delta 44
Re: Recording 4 Channels at Once - Delta 44
Have a go with Audacity 1.3.6
Thanks for the very prompt response on the first post!
Bummer, after installing the beta - 1.3.6, doesn't offer any options for more than 2 channels (stereo). Just to be sure, I checked the Audio Device Info - confirms my worst fears - only 2 channels for stereo available both for input and output.
Any dev plans in the future to allow multi channel use with M-Audio? Or is this a Delta 44 specific issue?
I've just done a search of the forum, and according to this post: http://audacityteam.org/forum/viewtopic ... +44+#p4065 you should set the recording device to "M Audio Delta 44 Multi" which "should" enable you to select 4 channels. If this does not work, you may need to update, or even "down date" the sound card drivers (hopefully it won't come to that).jeriatric wrote:after installing the beta - 1.3.6, doesn't offer any options for more than 2 channels (stereo).
Do let us know how you get on.
Yep, you nailed it. I was already trying the Delta 44 Multi, it was my versions that weren't working. I've rolled back to the following:stevethefiddle wrote: I've just done a search of the forum, and according to this post: http://audacityteam.org/forum/viewtopic ... +44+#p4065 you should set the recording device to "M Audio Delta 44 Multi" which "should" enable you to select 4 channels. If this does not work, you may need to update, or even "down date" the sound card drivers (hopefully it won't come to that).
M-Audio Delta 44 driver - Delta_WDM_5.10.00.5052v3
Audacity 1.2.6
These two versions work together no problem.
Note, I tried the rolled back driver with the 1.3.6 Beta, but after selecting Delta 44 Multi, still didn't offer me more than two channels as an option. I was pleasantly surprised that 1.2.6 did off me those channels and this time they worked!
stevethefiddle, thanks so much for your insights into what was a pretty simple problem. Much appreciated!
Thanks for reporting your results.
Several people have asked about the M-Audio Delta 44, so it's good to have confirmation that it can work, even if it's a bit fiddly to get started.
