Audacity Crash
narikutti
Audacity Crash
Post by narikutti » Thu Oct 23, 2008 10:22 pm
Hi,
Thanks for this great S/W!!! I have been using it for the past two weeks and recently, it's been crashing. Below is the error message from windows logs. I am using Windows Vista.
Log Name: Application
Source: Application Error
Date: 10/22/2008 5:09:57 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: lalithu-PC
Description:
Faulting application audacity.exe, version 0.0.0.0, time stamp 0x455814e4, faulting module audacity.exe, version 0.0.0.0, time stamp 0x455814e4, exception code 0xc0000005, fault offset 0x0012aff9, process id 0x518, application start time 0x01c933d5f9f1a680.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-10-22T10:09:57.000Z" />
<EventRecordID>30158</EventRecordID>
<Channel>Application</Channel>
<Computer>lalithu-PC</Computer>
<Security />
</System>
<EventData>
<Data>audacity.exe</Data>
<Data>0.0.0.0</Data>
<Data>455814e4</Data>
<Data>c0000005</Data>
<Data>0012aff9</Data>
<Data>518</Data>
<Data>01c933d5f9f1a680</Data>
</EventData>
</Event>
Is this a known issue? if so, is there a resolution? This generally happens while dealing with large files (> 10 hours).
Thanks,
Narikutti
