seal usb turntable
recoupbeer
seal usb turntable
Post by recoupbeer » Tue Oct 07, 2008 7:03 pm
just purchased turntable.recorrds fine, but i have nothing to plug RCA cable into.Can this be plugged into computer?or do i need sound card? or must i use another music centre etc ,to enable me to monitor sound in.
hellosailor
Re: seal usb turntable
Post by hellosailor » Tue Oct 07, 2008 7:32 pm
A "USB turntable" normally plugs directly into the USB socket in your computer, and a driver for the turntable or a generic USB audio driver allows the computer to input the audio directly from it.
Why would you need RCA jacks for a USB device?
If your turntable has outputs that end in RCA plugs, those should be 'extras' to allow it to be used with a conventional analog stereo, or the analog "line in" jack on a computer. Totally not necessary for a USB turntable to connect to the USB on your computer.
recoupbeer
Post by recoupbeer » Tue Oct 07, 2008 7:39 pm
I understand what you are saying,now. my problem is ,when I play album to record i cant hear it playing through computer speakers.cant monitor it.although it records and playback is loud and clear.
hellosailor
Post by hellosailor » Tue Oct 07, 2008 8:15 pm
Try enabling "software playthrough" in Audacity, that should let you hear what is being recorded.
If it doesn't--your OS and hardware might be part of the issue as well, post what they are too.
recoupbeer
Post by recoupbeer » Tue Oct 07, 2008 8:39 pm
playthrough software was the answer,many thanks hellosailor, now i can start experimenting i will no doubt be back with more queries.
