Input Drop down Menu
amarendra
Post by amarendra » Thu Oct 02, 2008 6:10 am
I downloaded the 'Audacity 1.3 Beta(Unicode) onto both my Desktop & Laptop. When I try to record music being played on the windows music player in the computer, I can see Flat line instead of any wave pattern and there is no recording taking place. On the drop down menu of 'Input' there are only three choices viz., Line-In, Rear Mic, Microphone. There is no 'Stereo mixer' option which I can see in the same Audacity proghramme on my laptop. I checked in the Preferences and also checked in the Sound manager from PC control panel. Advice please. - VA
Re: Input Drop down Menu
Post by steve » Thu Oct 02, 2008 5:09 pm
Some on board sound cards do not have a "Stereo Mix" option. Go into the Windows Control Panel and open the "Sounds and Audio Devices" section. Have a look in there to see what options are available with your hardware.
If you are using Vista, see here: http://audacityteam.org/wiki/index.php? ... s_Vista_OS
amarendra
Post by amarendra » Sat Oct 04, 2008 7:48 am
Thank you. I checked Properties of Volume control (sounds & devices) under options for recording I can only see Line-in, Rear MIC, Microphone. Does it mean this is a sound card problem. Do I have to change the sound card, OR Is there any other way I can get the recording get working. - Thanks once again -- amar.
Post by steve » Sat Oct 04, 2008 10:39 am
What sort of computer do you have?
what operating system?
laptop or desktop?
what sound card are you using?
what exactly are you trying to record?
amarendra
Post by amarendra » Sun Oct 05, 2008 8:06 am
I am trying to record music/song of a normal audio CD playing through Windows Media Player. I can listen to music through the speakers but there is no sign of recording at the same on Audacity. All I want to do is to convert the recording as MP3 and save it and then transfer to my mobile phone for me to listen while on travel. My computer is a Desktop and Dell dimension 5150 and the operating system is WindowsXP Professional media system. I don't know the sound card details, but when I looked in the Hardware in Sound,Speech devices, it shows as "SigmaTel Audio". -- Thanks-
Post by steve » Sun Oct 05, 2008 10:56 am
Even if your sound card does not support recording from CD, you can still get the music from the CD by digitally extracting it (and with better sound quality).
2 free programs that allow you to do it are:
C-Dex
EAC (Exact Audio Copy) - slower, but with good unscratched CD's produces perfect copies (as long as you set it up correctly by following the instructions carefully)
Once you have extracted the tracks as WAV files you can Import them into Audacity.
amarendra
Post by amarendra » Sun Oct 05, 2008 5:36 pm
That's great. I will certainly take your advice and try to extract and download to Audacity instead of bothering to record while playing the CD. You have been very helpful and good with your advice. Thanks a Lot. ---Amar.
entertainment
Installation of Audacity
Post by entertainment » Wed Oct 08, 2008 3:11 am
All of a sudden I am having a problem.I push the 'record' button and the flat line stays flat, no wave, which would signal that I am sending a signal into the program.I just had a new sound card installed in my 6 month old Dell Inspiron 530S, and I went to the Dell help site and they actually installed it for me and set it up through the remote feature they have for their customers. Bottom line is I know it is working.I reinstalled Audacity and I was wondering if the 1.2.6 drivers are installed when you download it.I am on home Windows Vista and the Audacity program set up in less than a minute.Is there something that I am missing? Thanks to anyone that could help me.
