Hello everyone,
I am importing radio interviews (MP3's) and then taking out the commercials. When I export the file to MP3 it ends up being larger than the original file, even though I have made the program shorter.
Can someone explain why this is happening? Any way to prevent it?
Thanks,
Robby
Export MP3 - Makes File Larger?
RobbyBarbaro
Re: Export MP3 - Makes File Larger?
Perhaps you are outputting at a higher bitrate than the original recording. Check your preferences.
