saved file does not open
TedArnold
Post by TedArnold » Tue Sep 23, 2008 7:57 pm
I'm having no luck opening a saved file. I saved it first as an aup file and then converted it to a wav file - both of which seemed to work fine. But then when I went to open the aup file to delete some of the intro noise, I can't open the file at all. It shows the file as being open, but there is no access to the file at all - I can't do anything to play or edit the file at all. Any help would be most appreciated.
Re: saved file does not open
Post by steve » Fri Sep 26, 2008 5:45 pm
The problem may be related to this: http://audacityteam.org/wiki/index.php? ... ement_Tips
