Batch export
genu
Batch export
Post by genu » Fri Sep 19, 2008 11:29 pm
I have at least 100 audacity files that I need to export them to mp3s is there a way to export all of them at once? without having to open each one and export them?
that would be really helpful
Re: Batch export
Post by steve » Sat Sep 20, 2008 3:07 am
genu wrote:I have at least 100 audacity files that I need to export them to mp3s is there a way to export all of them at once? without having to open each one and export them?
You mean you have 100 Audacity Projects that you want to export?
Unfortunately you will need to do this one at a time. It is strongly recommended that you export your finished projects as you go. This forum has hundreds of posts from users that have accidentally deleted parts of their project data and destroyed their projects before they had the audio safely exported. We usually recommend that you also export an uncompressed WAV version in case you ever want to do any further editing of the file (the wav version can be burned to CD if you are short of disk space).
