Playing last track over
littlejack
Post by littlejack » Sun Mar 04, 2012 1:58 pm
I have divided the tracks exported to wav and burned to cd but the player is playing the last track over and over (or part of it ) ?
When i play the cd it only shows track one i cannot skip tracks ?. thanks for any help .
billw58
Re: Playing last track over
Post by billw58 » Sun Mar 04, 2012 2:53 pm
Are you really using Audacity 1.2? If you are using Windows Vista or 7 you really should be using Audacity 1.3.
This tutorial in the Manual explains how to export multiple tracks for burning to CD. It is for 1.3.x, but the principles are the same for 1.2 (although the interface and menu commands will be different)
http://manual.audacityteam.org/man/Spli ... ate_tracks
-- Bill
littlejack
Post by littlejack » Sun Mar 04, 2012 3:37 pm
I am using windows xp am i on the wrong forum ? . Exporting as multi tracks puts each track into its own file ,can i not export so all the tracks are together and numbered .
How do i stop the last track playing over and over ?
billw58
Post by billw58 » Sun Mar 04, 2012 5:00 pm
What version of Audacity?
To burn separate tracks on the CD you need a separate file for each track.
I don't know why the last track plays over and over.
-- Bill
littlejack
Post by littlejack » Sun Mar 04, 2012 5:59 pm
I have a saparate track for each track what is the best way to send the tracks to Media Player so i can drag them to burn ?
Contact:
Post by steve » Sun Mar 04, 2012 6:22 pm
If you have a separate file for each track, just select them to burn to CD in whatever is the normal way for your CD burning program.
I don't use Windows Media Player so I can't tell you how to use that program.
littlejack wrote:I am using windows xp am i on the wrong forum
If you are using Audacity 1.3.x then you are on the wrong forum.
If you are using Audacity 1.2.x then you should upgrade as the 1.2.x series was discontinued years ago. You may however want to wait for a few days as Audacity 2.0 is due out very soon (it will be announced here on the forum and on the main Audacity web site).
